Here there are som props for 4mm shafts
www.tfl-hobby.de/Propeller/Bronze/2-Blatt/ but they start from 35mm upward. I run the 35mm one with a 2500KV motor, that performes great.
Or you could check out OSE, they cary tons of propellers. Mostly inch size shafts, but some in 4mm. They also have the TFL props these days :
www.offshoreelectrics.com/products.php?c...FL+Racing+Propellers
Props for 4mm shafts in small sizes, 30 to 35mm, are hard to come by. Teh best option might be to machine the shaft down to 3.18mm. That way there are far more props available for yout outboard. But you need machine bench for that, or a friend with acces to one.
You could also consider drilling out the thread on a M4 prop. That way you could use the Graupner props, but you need to have the equipment to do so. Although its a brass thread, so if you first drill with 3,5mm and that 4mm it could be done by hand, letting the drill find its own way.
Last option is to get a new propshaft 4mm to 3.18 and glue that on to a length of flex shaft to make new one.
www.tfl-hobby.de/Antrieb/Aussenborder/au...rop--Sicherung-.html
PS, no insult intended with that caliper remark of mine. I have no idea about your mechanical skills, and you would be supprised of the number of people hwo have trouble taking good measurements.
