Start Das Forum Die Backyard-Werft: unsere 152VO-Modelle Andere Baustellen Tools tips and trick to remove work hold taps plywood parts
THEMA: Tools tips and trick to remove work hold taps plywood parts
Tools tips and trick to remove work hold taps plywood parts 27 Sep 2021 16:36 #1
  • Rapid 1
  • Dank erhalten: 1
Hi
I thought I might ask what tools people have found that work best for cutting off and cleaning
up work hold tabs for a nice clean end results!
Any help would be appreciated .
Anhang:
Tools tips and trick to remove work hold taps plywood parts 27 Sep 2021 20:23 #2
Permagrit. :top:
www.permagrit.com/fxt103/
www.permagrit.com/fxt-104/
One of each, doublesided tape and a strip of wood inbetween.
And you have an amazing tool.
Tools tips and trick to remove work hold taps plywood parts 27 Sep 2021 22:09 #3
  • Rapid 1
  • Dank erhalten: 1
Hi Hate 69
Thanks for responding to my post appreciated your custom tool does it perform a bit like soft back sanding
sponge stick ? able to follow the profile of the frame contours to the parts . what thickness strip wood do you use
Tools tips and trick to remove work hold taps plywood parts 28 Sep 2021 18:22 #4
The one i use is a 5mm mahoganystrip and doublesided tape.
My boats need sharp angles.
So i prefer a stiff one :pfeif:
Tools tips and trick to remove work hold taps plywood parts 28 Sep 2021 20:52 #5
Yes, who dousn't....
Tools tips and trick to remove work hold taps plywood parts 28 Sep 2021 21:43 #6
:rofl: :rofl: :rofl:
:shakehands:
Tools tips and trick to remove work hold taps plywood parts 29 Sep 2021 18:22 #7
  • Jenjen
  • Dank erhalten: 158
I love my small gyokucho japanese saw
miniwerft-shop.de/p/japansaege-gyokucho-fein
But you have to use it carefully and only pulling: The saw blade is that thin, that it bends when pushed.
And after sawing:
www.permagrit.com/hand-file-flat-fine/
www.emc-vega.de/de/werkzeuge/permagrit1/...flachfeile-fein-f101
Tools tips and trick to remove work hold taps plywood parts 30 Sep 2021 02:09 #8
  • Rapid 1
  • Dank erhalten: 1
Hello everyone
Thanks for the information on tools to do the job appreciated, I am finding that a nice sharp chisel strike down with a good weighted plastic mallet does a pretty nice job at removing the rest of the work hold taps from the parts.
However has been a bit of trial and error my first attempts at removing the work hold tabs was with a utility knife would not recommend, on that note did anyone do any cad drawing of the parts for the Saucy willing to share as it looks like the company that makes the kit does not offer spare parts any additional help would be greatly appreciated
Anhang:
Tools tips and trick to remove work hold taps plywood parts 30 Sep 2021 07:18 #9
What parts would jou need? I have several in STL file.
Folgende Benutzer bedankten sich: Jimkpdp
Tools tips and trick to remove work hold taps plywood parts 30 Sep 2021 16:56 #10
  • Rapid 1
  • Dank erhalten: 1
Hi Lex
Thanks for responding to my post appreciated, great from the part sheets looking for the following
F1TA F3A FD1 Thank you
Anhang:
