Start Das Forum Die Backyard-Werft: unsere 152VO-Modelle Utilities / Flatbottoms A Foo-Ling for Rod (and one for me (-: )
THEMA: A Foo-Ling for Rod (and one for me (-: )
A Foo-Ling for Rod (and one for me (-: ) 18 Dez 2013 21:09 #141
You can put the popcorn away, the show is almost over ... :)
Only things I got left to do is to cut and stain the floorboard and the steeringboard and ask Rod if I shall assemble the side decks. Then the boat will be wrapped up and can start her long journey home.
:schwimm:
Da muss ich Dir mal ganz heftig auf die Schulterblätter hauen :bier:
A Foo-Ling for Rod (and one for me (-: ) 18 Dez 2013 21:55 #142
Carl just had to try it out. Now he's craving for one for himself.
A Foo-Ling for Rod (and one for me (-: ) 18 Dez 2013 22:19 #143
:popcorn: :popcorn:
A Foo-Ling for Rod (and one for me (-: ) 23 Dez 2013 03:13 #144
  • geraghty
  • Dank erhalten: 25
Assemble the boat and send her off............thanks,Rod..... :bier:
Shit happens :( 27 Dez 2013 13:37 #145
:kopf3:
While glueing on the portside sidedeck, two of the clamps sprang loose and ran havoc, knocking a big hole into the sidewall each. Now she's got her first combat marks before even ever having been out to sea:
Luckily I could do some spot repair, pics of that later today ...
:schwitz:
Shit happens :( 27 Dez 2013 14:31 #146
:troest:
Shit happens :( 27 Dez 2013 15:00 #147
After carefully rearranging the splinters and woodchips, I fixed them with the aid of some super glue. And that's how it looks like now:
Viewed from the right angle, it doesn't look that bad:
Maybe I can make it up a little more, but first comes the starboard sidedeck.
At least now I know, where not to put the clamps ...
A Foo-Ling for Rod (and one for me (-: ) 27 Dez 2013 15:04 #148
:schwitz:
A Foo-Ling for Rod (and one for me (-: ) 27 Dez 2013 15:15 #149
Die Klammern haben dir 1-Millimeter-FSH zermatscht? Was waren das denn für Dinger??? :glotz:
A Foo-Ling for Rod (and one for me (-: ) 27 Dez 2013 16:37 #150
Solche:
Und ich habe sie leichtsinnigerweise von aussen angesetzt. Während auf diesem gestellten Bild sich die Klammer an der Leiste verhaken kann, sind die Biester von der Decksplanke einfach abgerutscht. Erst haben sie heimtückisch so getan, als würden sie halten, dann machte es auf einmal "TOCK - TOCK" und es war passiert.
Bei der Steuerbord-Planke sind die Klammern jetzt von innen angesetzt:
