SwitzerCraft Bullet "Magnum" 07 Okt 2013 15:50 #1
ik loop al een paar weken te denken
om een Bullet te bouwen voor me Mercury
dan kan ik ook met meer wind varen
maar de afmetingen zijn moelijk te vinden
hij is nu 791mm lang
300mm breed
96.5mm hoog
is dit goed
nummer heb ik ook al uit gekozen VX 357
SwitzerCraft Bullet "Magnum" 07 Okt 2013 18:13 #2
Mooi keuze :rc:
SwitzerCraft Bullet "Magnum" 07 Okt 2013 19:25 #3
13'-6" lang -> 791 mm (ohne Overhangs)
63" beam -> 308 mm
Boden 3/8" -> 1,8 mm Beplankung
Höhe unklar (keine Angaben)
Motor Mercury KG9-H Thunderbolt (der Mark 30 passt eigentlich nicht dazu, dann schon eher der Mark 40, aber ohne open exhausts bzw. tuned pipes)
SwitzerCraft Bullet "Magnum" 07 Okt 2013 20:06 #4
zo beter
SwitzerCraft Bullet "Magnum" 08 Okt 2013 08:06 #5
dan wel van balsa anders is het te zwaar
SwitzerCraft Bullet "Magnum" 08 Okt 2013 10:58 #6
SwitzerCraft Bullet "Magnum" 16 Okt 2013 07:18 #7
wordt wat
SwitzerCraft Bullet "Magnum" 16 Okt 2013 07:19 #8
  • Dank erhalten: 3166
:popcorn: :popcorn:
SwitzerCraft Bullet "Magnum" 16 Okt 2013 09:02 #9
:nein2: -> http://www.boatracingfacts.com/forums/showthread.php?13985-Switzercraft-Bullet-Questions
boatracingfacts schrieb:
According to Classic Wooden Boat Plans, the Bullet was originally designed with a flat transom. While I don't want to accuse him of being disingenuous, I believe the transom should have a 13 to 16 degree rake. What few pictures of Bullets I have been able to find, all display an angles transom. Am I off here?
That's not really the structure of a Bullet. A Bullet is more of a stressed skin build. You are correct, the Bullet has a much more elaborate transom with an inset angled motor attachment
While the outer transom both port & starboard are 90 degrees, the center section somewhat inset was as 13 degrees.
I agree, the plans are for something that looks like a Bullett, but isn't nearly the same. For sure I'd make the transom look more original and figure out what the bottom really was and is before I started cutting wood.
SwitzerCraft Bullet "Magnum" 21 Okt 2013 08:09 #10
is het 1 van deze 2 oplossingen
ik vind de bovenste mooier
wat zal ik doen
