Start Das Forum Die Backyard-Werft: unsere 152VO-Modelle Utilities / Flatbottoms I hope it look like a Foo Ling
THEMA: I hope it look like a Foo Ling
I hope it look like a Foo Ling 27 Mär 2014 18:15 #1
  • drakkar
  • Dank erhalten: 8
hello,
some pictures to give you an idea of the progress
Henry and now, if he knew that he must finish sanding and varnish it smile less
out of water it seems stable :hops:
next stage,1mm gluing plywood on top with the opening for the front technical box pilot
A+
Manu
I hope it look like a Foo Ling 27 Mär 2014 18:29 #2
  • Rainer Ernstberger
  • Rainer Ernstbergers Avatar
I hope it look like a Foo Ling 27 Mär 2014 19:01 #3
:1st: :popcorn:
...but the Foo isn`t a Single Step :oops:
I hope it look like a Foo Ling 27 Mär 2014 19:09 #4
topchop schrieb:
:1st: :popcorn:
Moved to section "Utilities / Flatbottoms by mod
I hope it look like a Foo Ling 27 Mär 2014 19:14 #5
:top: :shakehands:
I hope it look like a Foo Ling 27 Mär 2014 19:22 #6
hello Drakkar,
c'est un bon début :rc:
(thank's Andy to have moved the subject)
I hope it look like a Foo Ling 27 Mär 2014 19:28 #7
le toppie :top:
I hope it look like a Foo Ling 28 Mär 2014 11:09 #8
  • drakkar
  • Dank erhalten: 8
oups
sorry
as you see I have much to learn
on models and different categories
a little work to fit Henry for the race:
Lifejacket
the non-mandatory helmet, but it's so good to Henry! :hops:
he keeps himself to sleep! :kopf:
shame that there have not motor, but it is in flight
A+ :rc:
Manu
I hope it look like a Foo Ling 28 Mär 2014 11:32 #9
I hope it look like a Foo Ling 28 Mär 2014 11:51 #10
:glotz: :top:
