Start Das Forum Die Backyard-Werft: unsere 152VO-Modelle Single Steps Serafino RIVA 1937
THEMA: Serafino RIVA 1937
Serafino RIVA 1937 01 Mär 2016 19:34 #31
:1st: That's a great idea, with that hole saw!!
Serafino RIVA 1937 01 Mär 2016 20:39 #32
one cut, one circle!
Serafino RIVA 1937 05 Mär 2016 18:17 #33
the pulley of the steering cable just pass the edge of the dashboard
when the steering wheel is in place, you can not see the pulley ...
Serafino RIVA 1937 05 Mär 2016 18:24 #34
... And it looks as if the ropes come from the steeringwheel pulley! :top: Nice!
Serafino RIVA 1937 05 Mär 2016 18:33 #35
dat was de doel
that was the goal.
Serafino RIVA 1937 10 Mär 2016 11:00 #36
Gema, one idea. There were two different kinds of steering hubs on the original boats:
1. front mounted hubs with the rope pulley located between the steering wheel and the steering board (as shown on your model), or
2. hubs leading through the steering board, with the rope pulley (hidden) on the front side of the steering board.
On your model you could easily just leave off the pulleys (between the steering wheel and the steering board). This would evoke the realistic impression, that your ropes directly lead to the (hidden) pulleys on the frontside of the steering board.
Serafino RIVA 1937 10 Mär 2016 14:51 #37
  • NickRoberts
  • Dank erhalten: 1
Wow...It's a work of art Gema.
you have given me a lot of good idea's.
Serafino RIVA 1937 10 Mär 2016 19:09 #38
here the original.
Serafino RIVA 1937 10 Mär 2016 20:37 #39
At first glance I thought the picture was of the model, and you made a realy superb fueltank .. :)
The model is raely a mirror image of the original, my compliments! :1st:
Serafino RIVA 1937 14 Mär 2016 19:03 #40
and to finish....
The boat sails very well. He jumps a little on the corners .... takes very fast speed ....
Gema :rc2:
edit : the set-up is
2300KV motor
3S battery
32mm propeller
