Start Das Forum Die Backyard-Werft: unsere 152VO-Modelle Single Steps SUNDANCER
THEMA: SUNDANCER
SUNDANCER 04 Feb 2013 22:32 #21
GREAT! :top:
Gema, you're building a really wonderful model. I like it very much!
Especially the technic-bay and the removeable cover... :top:
SUNDANCER 06 Feb 2013 20:39 #22
  • Dank erhalten: 680
Hei,
Work of wood, finished ... yet to be installed the mechanical
And....
... La classe.. :rofl:
SUNDANCER 09 Feb 2013 09:21 #23
the motot (a antic GTX 650) With A control rod.
SUNDANCER 09 Feb 2013 11:10 #24
Mark, two things that will cause you some trouble:
1.) the steering bar has to have a V-shape, otherwise the steering will not work correctly. The two fixing points of the steering rope have to be on the same axis as the steering shaft of the GTX (see red line in the following drawing):
2.) the SPEED 600 will be too heavy and too weak for this kind of hull. It will shift your center of gravity too far backwards because of it's high weight and won't have enough power to get your hull planing (floating freely). I'd strongly recommend the use of a 36 size BL motor.
By the way: what is the overall weight of your racer, including batteries, driver figure and RC?
SUNDANCER 09 Feb 2013 18:33 #25
Jo, thank you for the advice. I'll make the change.
the motor 600 is just for a steering test. I'll change with a bruschless..
for the cable, I think it used this.
regards,
SUNDANCER 09 Feb 2013 18:40 #26
Gema, we all use Dyneema, a thin but very strong thread (franz. fil).
You can buy Dyneema in a kite store (cerf-volant)...klick
SUNDANCER 09 Feb 2013 19:15 #27
Merci Xoff pour le lien,
it's just that I have this cable ... It is only 0.10mm in diameter, but I look for the dyneema
SUNDANCER 09 Feb 2013 20:44 #28
@ jo
I forgot, 1.8 kg maximum
SUNDANCER 10 Feb 2013 11:45 #29
Here the balance verdicte
less than 1.5 kg without the receiver and speed control
I change the steering bar.
but it is bad. The cable makes a triangle with the servo and the motor :evil:
SUNDANCER 10 Feb 2013 12:19 #30
Mark, I tried your cable on vintage model airplanes years ago. I experienced that the 0,1mm "Diamantlitze" rusts after some months and then it cracks. It also changes its length depending on temperature and strain - it is unsuitable for our needs, don't use it on your boat!
Just use a rope drum on the servo, dyneema steering rope and a solid steering bar with pulleys from Cap Maquettes - that will work for sure without causing any troubles.
