Start Das Forum No VO Vorstellung eurer "No VO"-Modelle Kaper-Brigg "Capra Negra" in 1:50
THEMA: Kaper-Brigg "Capra Negra" in 1:50
Kaper-Brigg "Capra Negra" in 1:50 29 Dez 2013 13:07 #11
  • Robin
  • Dank erhalten: 18
Ein Bekannter hatte mir dazu diesen Auszug geschickt:
hier ein kurzer Auszug aus Brian Lavery, Nelson's Navy (das ist zwar v.a. um 1800 - aber der Schiffbau von 1700 hat sich von 1800 kaum unterschieden):
"The problem of timber supply was one that had dogged British naval administrators for more than a century. Traditionally, British ships had been built of oak, and shipbuilders were reluctant to move away from this. Many frigates and sloops were built of pine, but these were poorly received by naval officers, and did not last long. After 1801 it became increasingly common to built ships in India, using native supplies of teak. These ships were much more successful, and lasted for many years.
But oak remained the main material for shipbuilding. The most important pieces were the curved knees which supported the decks, and the curved futtocks which made up the frame timbers. The grain of the tree had to be suitible for this, and compass timber, as it was called, could fetch very high prices. It might take a hundred years to grow timber suitible for an ordinary ship-of-the-line, and yet more for a first rate. This was the main reason why large ships were disproportionately expensive.
Shipbuilders preferred to use native oak if possible, and for more than a century landowners ahd been urged to plant trees. However, transport was always a problem, unless by water; timber more than about three miles from the sea or navigable river declined rapidly in value. Native timber was never sufficient, and large supplies were procured abroad, particularly in northern Europe. This was one of the main reasons why the navy went to great lengths to keep the Baltic open in 1800s."
Was sich ja auch mit dem Mondfeld deckt. Also Nussbaum, dass kommt ja auch farblich einigermassen an alte Eiche ran.
Das Deck wird dann wohl aus hellerem Holz sein, Linde vielleicht?
Kaper-Brigg "Capra Negra" in 1:50 30 Dez 2013 19:24 #12
  • Robin
  • Dank erhalten: 18
Nach dem ersten Schliff, man erkennt wo es hin geht :-)
Kaper-Brigg "Capra Negra" in 1:50 30 Dez 2013 19:52 #13
veel snel :pfeif:
Kaper-Brigg "Capra Negra" in 1:50 02 Jan 2014 22:29 #14
  • 152VO Headquarters
  • Dank erhalten: 242
Liebe Jungs,
uns ist allen bewusst, dass es 1000 interessante Baustellen gibt, über die es sich zu berichten lohnt.
Genau aus dem Grund haben wir gerade vor Kurzem eine mehrheitliche Einigung gefunden: gerne mal über den Tellerrand schauen, aber die Thematik bitte nicht ins Uferlose ausweiten, denn wir sind und bleiben eine Rennklasse. Und haben uns deshalb für den No-VO-Bereich auf einen ganz lockeren Rahmen geeinigt: ""Hier könnt ihr eure anderen Baustellen vorstellen, die im Maßstab 1:5,2 gebaut sind oder etwas mit Vintage Racing zu tun haben oder zu der Epoche 20er-60er Jahre passen."
So schön sie auch sein mag: die Kaperbrigg passt zu keinem dieser Kriterien. Darum nochmals: lasst uns bitte bei unseren Kernkompetenzen und bei den genannten Rahmenbedingungen für die "No-VO"-Sektion bleiben. Sonst postet Andy hier demnächst noch seine Kochrezepte! ;)
Kaper-Brigg "Capra Negra" in 1:50 02 Jan 2014 22:48 #15
  • Robin
  • Dank erhalten: 18
Sorry, das wusste ich nicht. Hatte hier in den Bereich geguckt und den Beiträgen nach ergab sich mir das nicht, dass das hier nur für 20-60´er Jahre oder 1:5,2 ist.
Der Thread könnte dann gelöscht werden.
