Start Das Forum Die Technikecke Outboarder AB ROBBE ROQUA Nachbau aus dem 3D Drucker....
THEMA: AB ROBBE ROQUA Nachbau aus dem 3D Drucker....
AB ROBBE ROQUA Nachbau aus dem 3D Drucker.... 21 Feb 2021 23:06 #11
  • Taskuvaras
  • Dank erhalten: 2
Hello
Hasse.69
thanks for your recongnition.
If the Outboarder adjusted as your example, i think its much "sucks air in".
On the first and only test drive (so far) this happens...
Actual no kavitation plate is installed and maybe its also a problem of the cooling water outlet.
I´m allready not at the end with this Design 8-)
For the next test drive it is adjusted max down, i want test this and want to lift the Outboarder until the Kavitation starts..
After the test drive i report the results ...
Thanks
AB ROBBE ROQUA Nachbau aus dem 3D Drucker.... 22 Feb 2021 00:42 #12
  • Dank erhalten: 756
This is the kind of speed you will achive with less drag.
We don't need the antikavitation plate, as we wan't some air to get sucked in to the prop. :rc:
To get some cool roostertail and go fast. :super:
AB ROBBE ROQUA Nachbau aus dem 3D Drucker.... 22 Feb 2021 00:47 #13
AB ROBBE ROQUA Nachbau aus dem 3D Drucker.... 22 Feb 2021 01:07 #14
  • Taskuvaras
  • Dank erhalten: 2
Thanks for the info,
maybe i have the wrong Prob for this Style. :super:
Every time if the Prob takes a deep breath of air the speed decreases instantly..
A prob with the same shape and bigger blades don´t reach the same speed.
The Motor and controller becomes Hot..
If the prob don´t takes a deep breath the speed is apporx 26-27 Kmh 8-)
That is enough for the classic Prinzess
(The Princess is no Racing Boat)
The Robbe Roqua reaches approx 14-15 Kmh
AB ROBBE ROQUA Nachbau aus dem 3D Drucker.... 22 Feb 2021 10:58 #15
  • Dank erhalten: 1674
Taskuvaras schrieb:
Wenn ich den AB so einstelle wie von Hasse.69 vorgeschlagen ist das doch schon eine Oberfächen Prob ??
Kann das so gehen??
Bei unseren Booten geht es genau so. Wie Du bereits selbst festgestellt hast, werden die Komponenten sehr schnell warm. Das liegt vermutlich an dem zu tief sitzenden Propeller.
Bei unseren Booten ziehen die Propeller in der Angleitphase gerne mal etwas Luft und "greifen" nach 2-5 Metern erst. Allerdings sind die Propeller auch aus Messung und scharf geschliffen. Wie sich ein gedruckter Propeller verhält kann ich nicht sagen (vermutlich weniger optimal).
Ich lese gerade, dass Du den AB an einer Robbe Prinzess betreibst. Dann ist Dein Setup mehr als nur eine Kanone auf einen Spatz. Ab einer gewissen Leistung (resp. Geschwindigkeit) wird jedes Modell unbeherrschbar.
Folgende Benutzer bedankten sich: Taskuvaras
AB ROBBE ROQUA Nachbau aus dem 3D Drucker.... 22 Feb 2021 11:24 #16
  • Taskuvaras
  • Dank erhalten: 2
Warm,
wirds nur mit dem großen Prob.
Aber vieleicht genau der und dann Motor nach oben.
Dann kommt das auf die Liste der zu testenden settings... :hops:
Der Druck Prob schlägt sich nicht schlecht, der gedanke ist durch diesen die richtige Grösse und Steigung heraus zu Fahren und dann was gescheites zu kaufen Alu oder Messing.
Diese Princess ist auch noch nicht "Fertig" gemacht, sprich das Urmodell. Als reines Testboot.
Keine scharfe Abriss kannte, der Spiegel ist nicht verstärkt und der Rumpfboden ist auch nur Grundiert (nicht besonders glatt).
Die Geschwindigkeit ca. 25-27 war noch sehr gut zu händeln auch für meine 12 Jährige Tochter :rc: .
Schneller soll die Prinzess nicht werden :nein2: !
Danke erstmal für die Tipps :top:
AB ROBBE ROQUA Nachbau aus dem 3D Drucker.... 22 Feb 2021 16:34 #17
You have a too "hot" setup for your goal of 25-27kmh. :oops:
Use a Graupner K-prop 31x1.4 and as a maximum 1800kV motor, probably a 1500kV would be enough. :pfeif:
With lower kV you will have a longer life on your flexshaft, less Amp for your ESC to handle too.
Will you share the Stl:s for your outboarder? :shakehands:
//Hasse.
AB ROBBE ROQUA Nachbau aus dem 3D Drucker.... 22 Feb 2021 20:30 #18
  • Taskuvaras
  • Dank erhalten: 2
You are the second person that tell me, the Motor is "to BIG/HOT" for this boat/setting :-o
By the way, this is the Motor thats fit´s mechanically perfect and maybe i search in the furture for another one with approx the same size and lower KV.
Sorry, at this stage i don´t share the .STL´s :nein2:
If you won´t one ? :idee2:
I can print one for you, only for the Material costs + Shipping.
If you want to be an "Alpha Tester".... :super:
AB ROBBE ROQUA Nachbau aus dem 3D Drucker.... 22 Feb 2021 20:56 #19
Thank you, but no thanks. :mrgreen:
I have my own 3D printers and i like to share, but it's ok to be different. I am. :-p
I've done a "dirtcheap" outboarder.
Brass, Cu-ni brakelines, solder and putty.
How come pictures doesn't work?
AB ROBBE ROQUA Nachbau aus dem 3D Drucker.... 22 Feb 2021 22:14 #20
  • Class C Hydro Racer
  • Dank erhalten: 1876
Hasse.69 schrieb:
How come pictures doesn't work?[/color]
I asked Lex a few days ago, he said the pictures are in quarantine :rofl:
