JiPeheL schrieb:
It's not because it was a museum. The only reason is that I don't visit any one with a toolbox ...
Jean-Phillipe, I know that these boats were still driven in the 1950s, but at that time they weren't really competitive anymore. Meanwhile the three pointers took their place as the fastest boats.
But, concerning the manufacturer: thinking about it again maybe you are right. It's not very probable that someone in France bought a boat in the USA (because of the shipping coasts). Moreover, if no french manufacturer has ever built a boat with this kind of hull (are you sure?), then maybe an amateur has copied a typical american conventional. I'm not informed about boat racing history in France in the 40s/50s and I only know a few french racing boats of that period.
As I wrote earlier, I took a lot of photos with a leaflet laid at some places so I could be able to find the real measurements. With that, it could be possible to draw a plan and build a model.
I tried this several times. The problem with drawing plans from photos is, that the photos are distorted in perspektive. That means, that it is not possible to get the correct cross sections (dimensions of the frames, angles of the running surface, etc.). Even if you have undistorted line drawings (top view, side view, bow view) you can't extract the cross sections. The biggest problem is always the running surface... slight differences in the measurements can cause a completely different running boat.
Wie ich schon sagte habe ich viele Fotos gemacht, mit denen man möglicherweise einen Plan des Bootes zeichnen und ein Modell bauen könnte.
Ich habe das einige Male probiert. Das Problem dabei ist die perspektivische Verzerrung der Fotos. Bedeutet: es ist nicht möglich, auf alleiniger Basis von Fotos die korrekten Querschnitte herauszufinden (Spantenabmessungen, Winkel der Laufflächen, etc.). Selbst wenn man unverzerrte Ansichtszeichnungen besitzt (Seitenansicht, Draufsicht, Frontansicht), lassen sich daraus keine Querschnitte extrahieren. Das grösste Problem dabei ist die Lauffläche: selbst aus kleinsten Abweichungen in den Abmessungen kann ein völlig anderes Laufverhalten resultieren.
