Start Das Forum Die Backyard-Werft: unsere 152VO-Modelle Utilities / Flatbottoms Serafino RIVA 1930
THEMA: Serafino RIVA 1930
Serafino RIVA 1930 22 Dez 2015 09:31 #11
Mooi dat het lukt met dat dunne fineer! :top:
Dieses Thema wurde beendet.
Serafino RIVA 1930 22 Dez 2015 11:55 #12
  • gamma
  • Dank erhalten: 168
I have used ammonia and ply many times for difficult shapes, it makes the wood soft and bendable but a planking, may be only in the bow area could make the shape even more accurate, i made my PT 109 in this way; the rest of the hull can be ply...after all the bottom is painted and the difference will not be seen
Serafino RIVA 1930 22 Dez 2015 18:33 #13
Gamma thank you.
I worked spoken with Poncelet that makes the same with the deck of his boat. (no ammonia) but bend the deck in both directions!
is't a 7mm panels.
Serafino RIVA 1930 25 Dez 2015 17:53 #14
the following.
The bottom and one side
Serafino RIVA 1930 25 Dez 2015 18:20 #15
:top: :bauen: :yepp: :popcorn: :winke:
Serafino RIVA 1930 25 Dez 2015 19:04 #16
  • gamma
:top: :winken:
Serafino RIVA 1930 26 Dez 2015 11:57 #17
second side
Serafino RIVA 1930 26 Dez 2015 13:47 #18
  • gamma
I am stunned by your work, it is so accurate and so fast...great craftsmanship Gema, congratulations :top:
Serafino RIVA 1930 26 Dez 2015 16:57 #19
hello Gamma,
this is not the first boat I build ;)
there is no problem .... I have the solutions to all ... So I do not waste time to think about what to do ..
And I work every day a little bit. (one hour) so it is going well ....
and that kind of boat is not very dificult ... I put more time to draw the plan to build the model! :evil:
Serafino RIVA 1930 27 Dez 2015 02:32 #20
  • gamma
gema1831 schrieb:
hello Gamma,
I have built many models too, mainly from building plans, but every boat i work on has its own challanging points...further on i have no idea at all how to draw a plan, for sure must be very interesting to build the model you have drawn...bravo! :top:
