Start Das Forum Die Backyard-Werft: unsere 152VO-Modelle Utilities / Flatbottoms French Foo-ling start / question on drawing...
THEMA: French Foo-ling start / question on drawing...
French Foo-ling start / question on drawing... 27 Dez 2018 21:09 #1
  • Elegallo
Hallo!
Ich heisse Erwan, ich bin Französisch, und ich spreche kein Deutsch... :)
I am thinking for quite a long time now about building a 152-VO RC boat, starting with a Foo-ling model.
I just started the construction based on famous drawing, but in order to start in a correct way, I have a question that I would like to clarify, regarding the distance between each "board".
I printed the base on A4 papers that I put together, and confirmed that the scale is OK by measuring on the "scale on paper"...
I have put each wood support according the drawing, which makes between support 1 and 2 a distance of 14.9cm, and between support 2 and 3 a distance of 13.5mm.
My problem is that it s written on another document, that support 1 to 2 shall be at 15.6cm distance each, and support 2 to 3 shall be at 13.7cm distance each other.
I do not know what s correct and what s wrong, I fear to start with wrong "set-up".
I checked length and width on my printed drawing, it seems to be correct (length 64,2cm and width 25cm)
Would somebody be able to help me to clarify this? :kopf3: :kopf3:
I will then keep you posted on the progress of building the boat.
Danke Schon!!
French Foo-ling start / question on drawing... 28 Dez 2018 10:00 #2
:muetze:
salut Elegallo et bienvenue sur le forum
tu n'es pas le seul " Französisch" ici.
Tu trouvera réponse à ta question, car il y a beaucoup de constructeur de Foo-ling sur le forum.
French Foo-ling start / question on drawing... 28 Dez 2018 17:54 #3
  • Elegallo
Hello Gema!
Thanks for your welcoming :super:
Yes, I saw that there is several french builders here :-)
During the week end I will cut the "skeleton" of the boat. I hope that I will get answer to my doubt to start assembly next week :hops:
But before that, it s now time for :bier: !
So cheers, and have a good week end!
Erwan
French Foo-ling start / question on drawing... 29 Dez 2018 08:05 #4
Hi Elegallo,
welcome in our community, we will help you as good as we can :super: Most of our members use the plans from user ANDY. You can send him a message and ask him for the plan. He has it in size A0 which you can print in a copy shop. On his plan the distances are 235/156/137/117 mm, as shown in your sketch (I think the sketch is a copy from Andy's plan).
French Foo-ling start / question on drawing... 29 Dez 2018 09:29 #5
  • Elegallo
Hi Floh!
Yes, that's the drawing from Andy that I use. I see, I used the small files from Andys package that I put together but bot the A0. By checking deeper, it s true that it seems the A0 file seems much better.
I will print it in a shop and will start again, hopefully I was just at the beginning :-)
Thank you for the tip!!
Erwan
