Start Das Forum Die Backyard-Werft: unsere 152VO-Modelle Utilities / Flatbottoms Foo-Ling VO115 "lucca" maiden
THEMA: Foo-Ling VO115 "lucca" maiden
Foo-Ling VO115 "lucca" maiden 17 Mär 2014 19:45 #1
  • Lucca
  • Dank erhalten: 32
Hello Jongens,Hallo Jungs,
Omdat dit mijn eerste boot is die ik bouwde naar het voorbeeld van Lex zijn "Bazigna" had ik het te druk met bouwen en vergeten foto's te nemen :-(
Ik heb wel een kort filmpje gemaakt van de eerste echte maiden trim, Lucca had al wel eens gevaren maar was toen gecrashed wegens een technish probleem :schwimm:
Since this is my first boat i built, the example of Lex his "Bazigna" I was too busy with building and forgot to take pictures :-(
I have a short video of the first real maiden voyage, Lucca already had sailed but was crashed because of a Technical problem :schwimm:
groetjes,Gruß
Luc
Foo-Ling VO115 "lucca" maiden 17 Mär 2014 19:50 #2
toppie gebaut :1st:
was ist passiert, dass deine Foo stolpert?
Folgende Benutzer bedankten sich: Lucca
Foo-Ling VO115 "lucca" maiden 17 Mär 2014 19:55 #3
ziet er toppie uit Luc :top: :top:
Foo-Ling VO115 "lucca" maiden 17 Mär 2014 21:22 #4
  • Rainer Ernstberger
  • Rainer Ernstbergers Avatar
:top: fährt super
Foo-Ling VO115 "lucca" maiden 17 Mär 2014 22:56 #5
Hi Luc,
congratulations to your maiden run! Seems to be a pretty fast boat.
Don't worry about the flip... if we can help you with technical advices just let us know.
Hope to meet you on the 3rd competition! :bier:
Foo-Ling VO115 "lucca" maiden 18 Mär 2014 19:14 #6
  • Lucca
  • Dank erhalten: 32
Hello Guys,
Thank you voor the rave words !!
@Topchop : yes at the end of the movie something happen i don't now it was a flip or somthing else but the boat stopped for 10 seconds then he start again :-o
@Jo_S : I hope to meet you to also do you now of there is a hotel nearby to stay the night ? :)
Foo-Ling VO115 "lucca" maiden 18 Mär 2014 19:51 #7
Your Foo is running very fast :top:
At my maiden with my Baby Bullet, I drove 3 minutes very fast without problems. :rc: So I startet again 20m later my Baby Bullet made a backflip, i cant`t explain what hapened :-(
-->click
Foo-Ling VO115 "lucca" maiden 18 Mär 2014 20:07 #8
  • Lucca
  • Dank erhalten: 32
Thank you topchop, yes it runs fast but it need still a lot of trimming :pfeif:
You Baby bullit is a dream !! perfect job :1st: what i see the same hapened with the foo (i think)
greetz
Luc
Foo-Ling VO115 "lucca" maiden 18 Mär 2014 20:17 #9
Thx Luc, :shakehands:
I hope I can see your Foo at the 3.Competition. So we can :rc2: with our Foos
I have nearly the same setup like Lex`s Foo. So it ist very fast and easy to drive. :top:
Foo-Ling VO115 "lucca" maiden 19 Mär 2014 09:15 #10
Hoi Luc,
Dat loopt prima, gefeliciteerd! Het bootje is lekker snel, ziet er goed uit. Voor zover ik het aan de video kan beoordelen zou je nog iets minder 'down tilt' op de motor kunnen hebben, of de schroef wat hoger zetten. Het lijkt alsof de boeg redelijk op het water gedrukt wordt, ze zou wat losser mogen lopen.
Das geht ja prima, gratuliert! Die Schüssel ist schnell, sieht gut aus. Wie ich das am Video beurteilen kann könnte der AB mit etwas weniger 'down tilt' auskommen, oder der Propeller kann etwas höher. Es scheint als wird der Bug zu fest aus dem Wasser gedrückt, sie könnte etwas freier laufen.
