Start Das Forum Die Backyard-Werft: unsere 152VO-Modelle Three pointers / Roundnoses Jupiter "Miss OTAGO"
THEMA: Jupiter "Miss OTAGO"
Jupiter "Miss OTAGO" 21 Jul 2015 18:37 #21
  • crono91
  • Dank erhalten: 9
Hello
for the hull I used the poyester resin and G4.J have used 25g of fiber to the inside floats.
I have put al the rear battery compartment .but weight is always! view photos.
Can be a mistake for the resin that gives too much weight.
Jo-s, to the center of gravity I do not know!.
Jupiter "Miss OTAGO" 21 Jul 2015 18:50 #22
  • gamma
  • Dank erhalten: 168
Which is the weight of your driver? I am not an expert but you could try to work on that: you may reduce the weight, for istance carving parts of the body out from balsa wood, or move the driver, as it is, until you achieve a better centre of gravity.
Jupiter "Miss OTAGO" 21 Jul 2015 19:46 #23
C´est un peu plus de lourd a´avant :pfeif: Dans cet etat,ca ne marcherait pas :pinch:
Jupiter "Miss OTAGO" 21 Jul 2015 20:18 #24
  • crono91
  • Dank erhalten: 9
Le pilote pèse 233g , c'est le mêm pilote que mon Atomite .
Mais même sans le pilote , il est trop lourd :kopf3:
:-o :-o :-o :-o
Michel
Jupiter "Miss OTAGO" 21 Jul 2015 20:24 #25
  • gamma
:o
Jupiter "Miss OTAGO" 21 Jul 2015 20:31 #26
crono91 schrieb:
... polyester resin and G4.J have used 25g of fiber to the inside floats. .... Can be a mistake for the resin that gives too much weight.
In my opinion, yes, that's the problem. The only solution i think will be to put as much weight as possible in the back, and negative tilt om the outboard to get the nose out of the water with a birst of thrust. If that dous not help ... then you have a serious problem :o
Or.... have you tried with only one battery? That might help aswell!
Jupiter "Miss OTAGO" 21 Jul 2015 21:22 #27
  • crono91
  • Dank erhalten: 9
no I have not tried a single battery.
But or positioned?
:glotz:
Michel
Jupiter "Miss OTAGO" 21 Jul 2015 22:18 #28
Only as example ! That´s the starting position of my Wetback with my heaviest driver :schwitz:
It´s fully equipped.
No need to worry about a sinking rear :rauchen:
Uli(The other boat is also very critical to get started. :oops: )
Jupiter "Miss OTAGO" 22 Jul 2015 03:06 #29
... measure it! :)
Jupiter "Miss OTAGO" 22 Jul 2015 06:10 #30
  • gamma
... measure it! :)
:rofl:
