Start Das Forum Die Backyard-Werft: unsere 152VO-Modelle Three pointers / Roundnoses Jupiter "Miss OTAGO"
THEMA: Jupiter "Miss OTAGO"
Jupiter "Miss OTAGO" 19 Nov 2014 21:24 #1
  • crono91
  • Dank erhalten: 9
Good evening to all :hops:
After my VO 91 Atomite Prime www.152vo.de/index.php/forum/flatbottoms/521-atomite-prime.html , I come to you for a new building.
Here I just got the kit Jupiter in France, thank you Jan.
I took as a reference work on Jupiter "Mom's Nightmare" Lex Verkuijls. www.152vo.de/index.php/forum/threepointe...moms-nightmareq.html
J started by fitting the parts and burnished wood.
I think I have a lot of questions following the installation will proceed.
Start of Construction
greeting,
  Michel :top:
Jupiter "Miss OTAGO" 19 Nov 2014 22:39 #2
Jupiter "Miss OTAGO" 19 Nov 2014 23:23 #3
Wish you lots of fun when building that boat. The number of Hydros is constantly increasing ... I guess sooner or later I need to build one for me as well.
Jupiter "Miss OTAGO" 20 Nov 2014 02:05 #4
Oh no,please,don´t do that :mrgreen: Please stay by your fantastic Flatbottoms and your great knowledge about eastern boats :bier:
Jupiter "Miss OTAGO" 23 Jan 2015 18:01 #5
  • crono91
  • Dank erhalten: 9
good morning :hops:
Here are some new Miss Otago .The shell is finished, I'm all mounted RC system.
j have a question.
What diameter pulley for?
greeting,
Michel :top:
Jupiter "Miss OTAGO" 23 Jan 2015 18:26 #6
  • Dank erhalten: 680
Salut Michel,
ça avance bien ton projet!
(P.S. tu as l'air mordu et c'est très bien)!! :rc: :rc:
pour le diamètre de la poulie. Celle que tu as faite devra être utilisée en prise directe sur le moteur. Pas de poulie de renvoie qui diviserait la longueur par deux.
google translate : :schwitz:
that your project is going well!
(P.S. you bite the air and it's very good) !! : rc:: rc:
for the diameter of the pulley. That you made should be used in direct contact with the engine.
No return pulley that would divide the length by two.
:rofl:
tu as l'air mordu : addict :plan:
Jupiter "Miss OTAGO" 23 Jan 2015 19:21 #7
  • crono91
  • Dank erhalten: 9
bonjour Gema :winken:
bravo pour l'article du Poncelet .
La poulie n est pas la mienne je cherche justement son diamètre
salutation
Michel :top:
hello Gema :winken:
Congratulations for the article Poncelet.
The pulley is not mine I was just looking diameter
greeting ,
Michel :top:
Jupiter "Miss OTAGO" 24 Jan 2015 09:45 #8
salut Michel,
ici on te propose des 40, 60 ou 80mm
www.152vo.de/index.php/store/storeequipment.html#ropepulleys
Jupiter "Miss OTAGO" 24 Jan 2015 11:00 #9
Jo made a tool for calculating the pulley diameter. It's an Excel-Sheet and can be found here: www.152vo.de/index.php/modelle/modelltoo...ring-calculator.html
(If you have difficulties understandig the instructions, just ask. We will be happy to help. :shakehands: )
Jupiter "Miss OTAGO" 02 Feb 2015 17:41 #10
  • crono91
  • Dank erhalten: 9
Hello everyone :hops:
electronics is installed, and also the foam.
greeting
Michel :top:
