Start Das Forum Die Backyard-Werft: unsere 152VO-Modelle Three pointers / Roundnoses Baubericht Saucy Shingle "McBullet"
THEMA: Baubericht Saucy Shingle "McBullet"
Baubericht Saucy Shingle "McBullet" 03 Aug 2015 12:24 #111
gamma schrieb:
Hi Martin, great job...as usual but i have a couple of questions
Where is the inlet of water for cooling the motor?The rounded silver pipe looks there for safety purpose only, in case the shaft breaks...
and one more question: what is it the small hole just above the propeller? sorry if mine are silly questions but as you know i am new to this type of propulsion :oops: i would be more expert in case of...steam powered outboard :mrgreen:
:bier:
There is no additional water cooling required. The whole AB is made of aluminium. An exellent thermal conductor.
The hole above the propeller is a mountig hole for the end piece of the lower leg.
You are right, the silver pipe is the Prop-Saver if the shaft breaks.
Steam powered AB. tuff tuff tuff...
Then do you have no problems with the yardstick! :rofl:
Baubericht Saucy Shingle "McBullet" 03 Aug 2015 12:46 #112
  • gamma
  • Dank erhalten: 168
:bier:
thank you Martin
yardstick? I do not know , I have still to study this chapter :lesen: :
:mrgreen:
Baubericht Saucy Shingle "McBullet" 03 Aug 2015 13:21 #113
Look here: www.152vo.de/index.php/rennklasse/klasse...tups.html#vo_utility
Baubericht Saucy Shingle "McBullet" 03 Aug 2015 13:24 #114
:bier:
I like the paddlewheel versions the most!
Baubericht Saucy Shingle "McBullet" 03 Aug 2015 16:57 #115
  • gamma
:bier:
:rc: :mrgreen:
Baubericht Saucy Shingle "McBullet" 03 Aug 2015 17:02 #116
And leave it to the Englisch to make a competition out of it :rofl:
Baubericht Saucy Shingle "McBullet" 03 Aug 2015 18:22 #117
  • gamma
:mrgreen:
Baubericht Saucy Shingle "McBullet" 04 Aug 2015 11:07 #118
martimcfly schrieb:
Ist schon mal bei jemanden der AB so weit nach oben geklappt und dort hängen geblieben, sodass der Propeller in der Luft hing?
Ja schon, bei Jan ... Aber der hat auch so einen komischen Fahrstil! :rofl: :stichel:
Bla bla bla :keule:
Baubericht Saucy Shingle "McBullet" 04 Aug 2015 11:35 #119
Hee, schau mal wer wieder da ist ... :top: Musst du nicht einpacken für morgen Jan, keine Zeit für's Forum :pfeif: :stichel:
Baubericht Saucy Shingle "McBullet" 08 Aug 2015 13:33 #120
:mrgreen:
