Jupiter"Number of the Beast" 11 Apr 2013 10:28 #1
Zeit für ein neues Projekt
Ich gehe meinem Boot auf dass Wasser anpassen
So jetzt ein kleines Boot
(Bildquelle: http://boatsport.org/kelly.html)
Mod: bitte IMMER Bildquelle angeben und verlinken!
Jupiter"Number of the Beast" 11 Apr 2013 18:04 #2
is weer eens wat anders ouwe mooi
kan het alleen niet lezen :-o
Jupiter"Number of the Beast" 11 Apr 2013 18:13 #3
  • Chynewalker
  • Dank erhalten: 141
I think this hull will need what I would refer to as a "chicken wing" near the transom. A chicken wing on a hydroplane is an extension of the chine planking above the top decking to prevent tripping when turning. The diagram shows the side extending all the way rearward, but it isn't completely apparent that it is doing so.
You can sort of see what I am referring to in this photo of my Hedlund hydro. When they were first built, it was discovered that although very fast in the straight-aways, it would occasionally "catch" in the turns, sometimes hard enough to flip the boat because the chine would dip under water due to its low profile. The chicken wing effectively raised the height of the chine without affecting the aerodynamics of the hull. The Jupiter is very similar in design with an aerodynamic profile ending in a very short transom and adding the chicken wing should help keep the boat upright when turning sharply.
Anhang:
Jupiter"Number of the Beast" 11 Apr 2013 18:18 #4
Time for a new project!
Go to the lake to tune my setup.
So, now a small boat
:mrgreen:
Jupiter"Number of the Beast" 11 Apr 2013 18:21 #5
Hi, talking about something like winglets on a plane?
Jupiter"Number of the Beast" 11 Apr 2013 19:17 #6
Though it looks similar, it serves a completely different purpose. If I have understood correctly, the "chicken wing" ist the extension of the chine upwards above deck level. This shall prevent the otherwise very low chine from being submerged while turning.
You can probably compare it to the front panel of a airboat, which effectively keeps the very low deck above the water:
klick
Das sieht zwar ähnlich aus, dient aber einem völlig anderen Zweck. Wenn ich das richtig verstanden habe, sind die "Hühnchenflügel" die Verlängerung der Chines nach oben über das Deck hinaus. Dies soll verhindern, dass die sehr flache Chine in Kurven untergetaucht wird.
Anschaulich lässt sich das vielleicht mit dem vorderen Paneel eines Sumpfgleiter vergleichen, dass das sehr niedrige Deck zuverlässig über Wasser hält.
Jupiter"Number of the Beast" 11 Apr 2013 19:18 #7
http://www.gwoltal.myfastmail.com/files/Airboat
Quelle: activerain.com/blogsview/679119/life-les...m-an-airboat-captain
Edith says:
Embedding the image doesn't work, please use the link to the page given above.
Jupiter"Number of the Beast" 11 Apr 2013 20:03 #8
Exactly right! :top:
In fact the Jupiter has chicken wings:
(Bildquelle: eigenes Foto)
Jupiter"Number of the Beast" 11 Apr 2013 20:38 #9
The 3D is ready
Jupiter"Number of the Beast" 11 Apr 2013 21:21 #10
Kende gij geen duits k##t
:rc: :bier:
