Start Das Forum No VO Vorstellung eurer "No VO"-Modelle KAISER K-360 scale 1/5.2
THEMA: KAISER K-360 scale 1/5.2
KAISER K-360 scale 1/5.2 31 Dez 2014 14:12 #31
  • blumeck
  • Powered by Krombacher
  • Dank erhalten: 172
you are on the woodway :)
however, you need to focus the beam. this is only possible with a stator.
Meik :bier:
bibo ergo sum
KAISER K-360 scale 1/5.2 01 Jan 2015 00:18 #32
hello Meik
tell me more ... what is a stator?
KAISER K-360 scale 1/5.2 01 Jan 2015 11:08 #33
That is a part behind the impeller that redirects de waterflow back to a straight and coherent stream. Directly from the impeller is swirls in one direction, redirecting it improves thrust and efficiency. In the Graupner picture it is part nr 15. Without a stator you loose a lot of thrust.
Quelle: static.rcgroups.net/forums/attachments/1...44-graupner_wjet.gif
Also type in 'jet drive stator' in Google, that provides a lot more pictures.
KAISER K-360 scale 1/5.2 01 Jan 2015 11:17 #34
dank U Lex
Nu is het duidelijk !
KAISER K-360 scale 1/5.2 02 Jan 2015 16:48 #35
what an adventure !!!
I did a new test of the turbine. A stator placed after the Impeller and it works great !!!
BUT YES! :kopf3:
the boat having no deck ... he lifted the nose and the water entered largely from behind ..
and splash! it sank in deep 1.20mètres :schwimm:
I recuperate him :schwitz:
Gema (not very clever)
KAISER K-360 scale 1/5.2 02 Jan 2015 17:05 #36
:rofl: :rofl: :rofl:
but finally you did it Gema :top:
KAISER K-360 scale 1/5.2 02 Jan 2015 17:13 #37
yes Rainer,
I did it! :pfeif:
now everything dry .... I look tomorrow if there are damages ... :pinch:
KAISER K-360 scale 1/5.2 03 Jan 2015 11:21 #38
result:
Battery: ok
Receiver: ok
Servo: ok
Motor: ok
only the ESC: ko!
I've did a new order in H.K.
:schwitz:
KAISER K-360 scale 1/5.2 03 Jan 2015 11:31 #39
gema1831 schrieb:
only the ESC: ko!
For next time: spray it with WetProtect! Works for fine for me.
KAISER K-360 scale 1/5.2 03 Jan 2015 12:06 #40
hello Lex,
denk je dat het voldoende is?
De boot bleef een uur in het water! :schwimm:
zal toch proberen.... kan niet slecht zijn
