Start Das Forum Die Technikecke Outboarder Wich engine now
THEMA: Wich engine now
Wich engine now 25 Mär 2018 12:51 #1
  • Jean-luc Cayre
  • Dank erhalten: 23
Hi everybody,i come back after some days without new.
For my project of 152VO i search engine but the dealers propositions are not very imortantes or very expensive.
Do you have an alternative.
Where do you take your engines.
Wich engine for begin in this activity with good performances but not to much expensive.
I think this question was asked several times, but is it possible to upgraded the actual data to know wich engines are available.
In alternative, do you think it is better to make the transmittion yourself ?
Thank you in advance at all comunity.
Jean Luc from france
Wich engine now 25 Mär 2018 19:49 #2
Hi Jean Luc,
A good an fairly cheap outboard is the TFL Mini. This is almost the universal 152VO outboard. Jou can order one here at TFL:
www.tfl-hobby.de/Antrieb/Aussenborder/au...ein-450--3450KV.html
or here at HobbyKing
hobbyking.com/en_us/sprint-f3-tunnel-hul....html?___store=en_us
They are identical, from HobbyKing will take 8 to 12 few weeks to get to Europe.
The TFL Mini is ready to run, but it is advisable to change the original brass (!) shaft bushing for two metal-teflon bearings.
Wich engine now 25 Mär 2018 21:33 #3
  • Jean-luc Cayre
  • Dank erhalten: 23
Thank you lex.
I see to obtain a engine from HOBBY KING.
Wait and see.
Wich engine now 26 Mär 2018 12:16 #4
salut Jean-Luc,
le H-King est un très bon choix. Personnellement je n'ai jamais attendu plus de 4 semaines pour recevoir mon colis.
Par contre, il faut impérativement changer le moteur pour rester "dans les cloux" pour naviguer en 3S. Où naviguer en 2S, ce qui est un peu peu. (le moteur d'origine est un 3000 Kv).
Wich engine now 28 Mär 2018 05:16 #5
  • Jean-luc Cayre
  • Dank erhalten: 23
Thank you gema.
I never ordered from HOBBYKING.Only from BANGGOOD.
I will test.
Thank you for all.
Jean Luc
Wich engine now 31 Mär 2018 11:41 #6
Wich engine now 09 Apr 2018 06:10 #7
  • Jean-luc Cayre
  • Dank erhalten: 23
Thank for yhe links.
