Start Das Forum Die Technikecke Outboarder Flexwelle?
THEMA: Flexwelle?
Flexwelle? 15 Mai 2021 21:27 #1
  • Kaiwofg
  • Dank erhalten: 13
Hello all,
I’m working on a self build outboard, and would like to know whats the best to use for the tubing for the shaft?
I want to use a 3,2mm shaft and do i need teflon lining or can i let the shaft spin in brass tubing only?
I’m using a bush bearing at the end.
My plans are based in the copper plated ones of mr. Mcfly. I’m curious what hé is using?
Greetings kai
Flexwelle? 16 Mai 2021 09:17 #2
  • Dank erhalten: 756
No PTFE for me, i have used only brasstubing, last 3 years.
Flexwelle? 16 Mai 2021 13:40 #3
  • Kaiwofg
  • Dank erhalten: 13
OK thanks, so thats what i'm going to use.
Do i take a 4mm inner diameter for the 3.2mm shaft?
Flexwelle? 16 Mai 2021 20:19 #4
Acctualy, i bought 5meter of copper/nickel 3/16" from an autopartsdealer.(Think i paid 20€)
It is for making brakelines on the car.
Have no idea what inside dia is or wall thickness, it just works.
Like this:
www.ebay.de/itm/251962997391?hash=item3a...f:g:L1EAAOxyoA1RQPKK
Folgende Benutzer bedankten sich: Kaiwofg
Flexwelle? 16 Mai 2021 20:59 #5
  • Class C Hydro Racer
  • Dank erhalten: 1876
Hasse.69 schrieb:
Acctualy, i bought 5meter ...
That is enough for 40 outboarders :muetze:
Flexwelle? 17 Mai 2021 07:58 #6
  • Dank erhalten: 3220
I use 4x5mm brass tubing for a 3.2mm shaft with no teflon lining. I have built several ourboards like that, I think it is the best solution. The 4mm inner diameter with model grade brass tubing usualy means an actual 4.2mm diameter, which is just about ideal.
Flexwelle? 17 Mai 2021 13:49 #7
40+ Rolf :bier:
My homebuilt outboarder that tried to "mount" your Flugan uses less then 11cm of that brakeline.
Measured to 0.7mm wall thickness.
So 4.76-1.4= 3.36mm.
Do you have a link for your tubing, Lex?
I can't find any.
*edit* found it: www.ebay.de/itm/322384765167?var=5113446...f:g:ckUAAOSw6kdgdCVs
Flexwelle? 17 Jun 2021 20:43 #8
  • Kaiwofg
  • Dank erhalten: 13
Die flexwelle ist dar!
Er braucht nog vet!
Flexwelle? 17 Jun 2021 21:42 #9
Meinst du mit 'nog vet' 'noch Fett' ?
Ich nehme seit Jahren das
Bootsfett von Liqui Moly
Funktioniert super :super:
Flexwelle? 28 Jun 2021 18:41 #10
  • Kaiwofg
  • Dank erhalten: 13
Hallo floh,
Das meine ich ja!
