Start Das Forum Die Backyard-Werft: unsere 152VO-Modelle Utilities / Flatbottoms Baubericht Speedliner Corsair M-510 'Maverick'
THEMA: Baubericht Speedliner Corsair M-510 'Maverick'
Baubericht Speedliner Corsair M-510 'Maverick' 26 Jan 2013 19:22 #1
Step 1 of my Speedliner Corsair M-510. I got the drawings from Steffen.
Baubericht Speedliner Corsair M-510 'Maverick' 26 Jan 2013 19:25 #2
Step 2:
The first mile stone is reached; the frames are finished!
Bow section is glued:
Next step: gluing the laths on the frames.
Baubericht Speedliner Corsair M-510 'Maverick' 26 Jan 2013 19:28 #3
Before gluing the laths I stained the frames. Using a roller works great!
The frames are setup on the building board.
The middle lath is glued:
Baubericht Speedliner Corsair M-510 'Maverick' 26 Jan 2013 19:31 #4
Step 3:
[/QUOTE]
Baubericht Speedliner Corsair M-510 'Maverick' 26 Jan 2013 19:36 #5
Step 4, Planking the hull:
I also made the turnfin from aluminium.
Baubericht Speedliner Corsair M-510 'Maverick' 26 Jan 2013 19:40 #6
Step 5:
Baubericht Speedliner Corsair M-510 'Maverick' 26 Jan 2013 20:20 #7
ik zet het er maar weer even bij
strak bootje :side:
Baubericht Speedliner Corsair M-510 'Maverick' 03 Feb 2013 20:41 #8
Step 6:
The floor plate and the steering plate are fixed.
The emergency power off supply:
The receiver plate. First fit, measure and then make :)
Time for the next staining round:
After staining I applied two layers of laquer to the inside of the hull and the separate parts.
I tensioned the steering wire to align the brass tubes to guide the steering wire. Finally the steering wires will end up higher.
The bow section is stuffed with pool noodle. The narrow nose doesn't have room for too much pool noodle, but I guess it is enough.
The top laths are also placed and sanded down. The middle lath in the bow section will be partly removed lateron because of the latch.
Next update the deck will be on! :)
Baubericht Speedliner Corsair M-510 'Maverick' 03 Feb 2013 23:33 #9
I can't help myself. Somehow I like that boat :top:
Baubericht Speedliner Corsair M-510 'Maverick' 03 Feb 2013 23:39 #10
Great! Thanks for the many pics! :top:
(Don't forget the toe holes in the floor board - your driver will appreciate them!)
... makes me wonder why :rofl: :)
