Start Das Forum Die Backyard-Werft: unsere 152VO-Modelle Utilities / Flatbottoms Atomite Build
THEMA: Atomite Build
Atomite Build 20 Feb 2019 13:21 #11
steve_NZ schrieb:
I need to start thinking about power and RC gear before I go too much further. I'd really like to cover the front hull in polyester cloth and not have a hatch, think I saw a build on here where someone did that? Think they had a sliding floorboard.
Welcome to 152VO.
Like this?
My own pictures
www.152vo.de/index.php/forum/flatbottoms...eq.html?limitstart=0
Ps use epoxi and 25-40 grams of fibreglasscloth, not polyester.
Folgende Benutzer bedankten sich: steve_NZ
Atomite Build 20 Feb 2019 13:46 #12
You don't need fiberglass or other fabric. 80% of our boats have only clear coat (1-K or 2-K). My boats are only planked with 0.6mm (top) or 1.0mm (bottom) plywood and sealed with clear coat.
Atomite Build 20 Feb 2019 20:46 #13
  • steve_NZ
  • Dank erhalten: 1
Kay_01 schrieb:
Hi Steve
tell me, why do you have ordered the building kit of the spitfire? When I see the quality of your Atomite, I believe you'll not impressed by the kit of the spitfire.
Realy nice build! :top:
Best regards, Kay
Thanks Kay, I ordered the spitfire kit right at the start when I first discovered 152VO, I saw a few builds of it on here and thought it looked pretty good. We'll see what it's like when it arrives. I then got impatient and without a current project in the workshop decided to build another type from plans "as practice". I'm glad I did as I have been learning little things along the way (just wish I had of written them down so I could remember them :-( )
I have built some 1:1 scale boats before (just small sailing dinghy and kayaks etc) but never RC boat - but the principles are all the same.
Atomite Build 20 Feb 2019 20:54 #14
  • steve_NZ
  • Dank erhalten: 1
Hasse.69 schrieb:
Welcome to 152VO.
Like this?
Thanks, yes something like that, that looks nice and strong. Is there something that goes over the back part of it as well - to stop it lifting?
When I mentioned polyester cloth I was meaning to cover the forward deck with. I use it to build skin on frame kayaks with (like in my profile pic)
Atomite Build 20 Feb 2019 21:08 #15
  • steve_NZ
  • Dank erhalten: 1
I need to order all my running gear and as this my first boat I don't really know where to start, well I have an idea but is it possible for someone to give me a "shopping list" please.
I've seen that the most common outboard is this one (sprint F3 tunnel hull):
photo from Hobby King hobbyking.com/en_us/sprint-f3-tunnel-hul....html?___store=en_us
Is that correct? Also while we're here I see that this one has water cooling - do I need to install a pickup in my hull or is that the water pickup tube I see hanging down from the motor? Also.... I've seen pics of some outboards with really cool retro hoods/covers - do people make these themselves or can they be bought somewhere?
Is there a particular servo that everyone uses?
Radio/receiver/battery I can pretty much work out myself. I have a set here already from an aircraft but it's the stick type so might just get another set (pistol type), they're cheap enough these days.
I just need a bit of help with the boat specific stuff - motor/servo/steering gear etc
Atomite Build 20 Feb 2019 22:54 #16
  • ONLINE
Hi Steve,
yes, this is the common outboarder.
yes, the cooling is the tube hanging down from the outboarder.
I use the Turnigy Marine 60A speed controler in all my boats and I cool it with the same tube which I use for cooling the motor.
There is no common servo, look for a waterproof servo with metal gear. You can find cheap ones on aliexpress.com
I ordered a servo which was only 22 dollars.
For the covers ask Lex. We print it by ourselves with a 3D printer.
Atomite Build 21 Feb 2019 19:16 #17
  • steve_NZ
  • Dank erhalten: 1
Floh schrieb:
Hi Steve,
Thanks for that. So those hoses are quite flexible? I mean for the cooling tube that goes from the outboard up to the ESC as it has to flex with the outboards movement/turning?
I don't suppose you have a photo of your setup with all the tubes attached?
Also, where do we get the rigging blocks from?
Atomite Build 21 Feb 2019 22:22 #18
  • ONLINE
Hi Steve,
here is the website where you can order the rigging blocks. Not cheap, but the best!
www.cap-maquettes.com/
Fotos of my setup will be uploaded in a few minutes.
Atomite Build 21 Feb 2019 22:36 #19
  • ONLINE
Hi Steve, flexible silicone hoses, otherwise steering is not possible:
From the outboarder to the ESC, Turnigy Marine 60A:
From the ESC outside the boat:
The blocks from Cap Maquettes. The steering wheel is my own construction.
Here you can see the steering wheel in action:
Flohs_Steering_Wheel
Atomite Build 22 Feb 2019 01:16 #20
  • steve_NZ
  • Dank erhalten: 1
Thats great Rolf (I think thats your name) pictures say much more than words (it's a pity most of the build logs no longer have their pics available).
What size blocks are those - about 5mm?
Also what diameter silicone hose? I don't have my motor yet so can't measure anything.
Sorry for all the questions but I don't have any model shops where I live so I have to order everything online (and 90% from overseas as well) and I like to order as many things as I can at once otherwise the shipping to New Zealand kills me.
many thanks
cheers
Steve
