Start Das Forum Die Backyard-Werft: unsere 152VO-Modelle Utilities / Flatbottoms Atomite Build
THEMA: Atomite Build
Atomite Build 22 Feb 2019 07:46 #21
Hi Steve,
yes, my name is Rolf, but my nickname since more than 40 years is Floh (Flee) :rofl:
Don't hesitate to ask, I started here 3 years ago and without this very good community it would be impossible for me to build my first boat!
Block size is 10mm, silicone hose diameter outside 5mm, inside 3mm. The lead through inside diameter is 5mm.
On this photo you see an expensive solution:
Here is a cheap solution, works also fine:
This is the Aluminium lead through:
Here the front block:
Here you find the shackles: www.newcapmaquettes.com/Nickel-Plated-Br...ckles.html?fromrec=1
You can buy the metal rings in a fishing tackle shop.
This is the front block: www.newcapmaquettes.com/Poulies-de-renvo...142LB.html?fromrec=1
This the rear one: www.newcapmaquettes.com/Poulies-a-manille-PM10LB.html?fromrec=1
Silcone hose: www.tfl-hobby.de/Schlaeuche-u--Zub-/Silikonschlauch-3---6.html
Lead through: www.tfl-hobby.de/Schlaeuche-u--Zub-/Schl...er-5mm-Schlauch.html
For the outboarder, floating bearing, much better than the original one: www.tfl-hobby.de/Antrieb/Aussenborder/au...luminiumbronze-.html
Flexdrive as a spare part, you need a couple of them during a year: www.tfl-hobby.de/Antrieb/Flexwellen/Flex...r-Rolle--rechts.html
Take the measurement before you order!
Flexdrive brazing: www.tfl-hobby.de/Antrieb/Flexwellen/Flex...n-und-schleifen.html
Coupler for the round flexdrive (original is square!): www.tfl-hobby.de/Kupplungen/fuer-4-mm-st...-3-2-mm-VA-1012.html
I hope this helps a little bit.
Atomite Build 22 Feb 2019 07:57 #22
Steve, if you like you can have a look on my website. There you can find further informations and a lot of photos from my Baby Bullet (also a modification of the outboarder and another water cooling) and from the Foo Ling.
You can download it. Perhaps this also helps:
BABY BULLET
FOO LING
Note: in this community are a lot of guys who are much better in building a model! I am somewhere between low and high level :bauen:
Atomite Build 22 Feb 2019 08:43 #23
  • steve_NZ
  • Dank erhalten: 1
No... this helps a LOT! Thanks very much Flea I really appreciate it. It's Friday night here and a few beers after work so will leave until tomorrow morning to study this further.
Cheers :bier:
Atomite Build 26 Feb 2019 23:24 #24
  • steve_NZ
  • Dank erhalten: 1
Not a lot to report but have made a stand for the boat, put on the outboard battens, transom/bottom hull supports (knees?), keel and a floorboard for servo.
Oh yeah, and the spitifire turned up....
Atomite Build 27 Feb 2019 07:35 #25
Good job so far, well done :1st:
Atomite Build 27 Feb 2019 09:01 #26
Verry nice job on the Atomite! The keel is interesting. Normaly we put a fin underneath the hull to stabilize the cornering, but this keel could also do the trick. I'm verry interested in how she will run.
Keep up the good work! :top: :bauen:
Atomite Build 27 Feb 2019 09:13 #27
Oh yes, a wooden turnfin. How do you change it when it's damaged?
Look at this Aluminium fin from my boat after a race crash:
