Start Das Forum Die Backyard-Werft: unsere 152VO-Modelle Utilities / Flatbottoms 1st 152VO-the Vary First Speedy
THEMA: 1st 152VO-the Vary First Speedy
1st 152VO-the Vary First Speedy 09 Jun 2024 16:59 #1
  • clipper888
  • Dank erhalten: 12
Dear all sir : Thanks for Rolf & Andy sir's speedy building plan
After reading much more building reports,My first 152 is under construction,only one thoughts "it's long
way to the top ,if you want to building boat' :kopf3:
this is my first time do wooden works,working hard in this weekend :bauen:
Will continue update this project !!
By the way 06/10 is "Dragon boat festival" (端午節) in Taiwan,so wish all Happy 端午節!!
Anhang:
Folgende Benutzer bedankten sich: Klemens, tika, Hasse.69, Floh, OldGun
1st 152VO-the Vary First Speedy 11 Jun 2024 18:12 #2
  • clipper888
  • Dank erhalten: 12
Dear all sir :
Got some problem
In the stage of temporary assemble ,I found the straight bar is not really straight ,is it correct? :-(
I have compare the drawing the parts size is match
1st 152VO-the Vary First Speedy 12 Jun 2024 17:54 #3
  • OldGun
  • Dank erhalten: 634
Hello Yi Kai,
drawings and the reality could have a difference.
I am no expert but all the plans i have received are coming from Original Drawings in Foot and Inch.
These are then converted into Milimeters and then translated into 1:5,2 !
Therefor i am pretty sure that a Milimeter difference could happen and then the reality comes.
If the wood is not 100% straight in measures all down the complete "Stick", then you could have differences in Drawings versus Frame building.
My recipe for that is to measure the plan at start, mid and end between Stringer and Battens.
If you can measure at minimum at start and mid the same size, then the last "fit" needs sanding to get the same distance between the start and the mid of the complete frame.
Otherwise your complete Framesetup is fooling you after all the next steps (Planking, fitting and so on)
Best Heico
p.s. the Keel is the Main measure for every Boat, a wrong Keel get's a wrong Boat !
Folgende Benutzer bedankten sich: clipper888
1st 152VO-the Vary First Speedy 12 Jun 2024 22:40 #4
If you look at Andy's build since he did the drawing.
152vo.de/index.php/forum/flatbottoms/2157.html
Look through all his buildlogg
1st 152VO-the Vary First Speedy 13 Jun 2024 17:22 #5
  • clipper888
  • Dank erhalten: 12
Helico sir :
Thanks for sharing your recipe ,its a good lesson learn for me “measure is the first”
I do some measurement works , and will revise the frame trench distance ,right now can sleep well :sofa:
Hassle sir:
Yes I have been reading many times and the others building plan ,but I just can’t finding out what’s wrong
But now I find ! “measure the drowning first “
1st 152VO-the Vary First Speedy 10 Jul 2024 14:49 #6
  • clipper888
  • Dank erhalten: 12
Dear all sir
After hundreds of years, I am still struggling with these pieces of wood. It seems that I am far away from completion. Inevitably, I also made some mistakes that caused me to have trouble sleeping at night.
For example, I sawed off the pine wood that extended to the end of the ship and cut off the wood on one side of the ship. Or the bar tension makes me confused
But this is where I'm at right now. I'm struggling with where to place the glue on the base. :bauen:
1st 152VO-the Vary First Speedy 10 Jul 2024 18:21 #7
  • OldGun
Hello Yi Kai,
i am not sure what the question means "How to glue it"
If you need a tip what kind of glue you should use, then the question is:
Did you laquered the Chines and the Frames ?
If yes then you need a 2K Epoxy glue (in Europe there would be "UHU Endfest 90 Min" a possibility)
If no (only stained) then you can use waterresistant woodglue ("Ponal Wasserfest")
If the question was how to fix it to the chines, then look at Andy's Build Log
Andy's Pictures how to fix
The bottom could be fixed with some iron weight or with adhesive tape wrapped around the raw construction.
Sometimes it makes sense to split the glueing into two separate jobs for the bottom.
First the flat part and then the round part.
Best Heico
