Start Das Forum Die Backyard-Werft: unsere 152VO-Modelle Utilities / Flatbottoms Flatbottom Construction Report
THEMA: Flatbottom Construction Report
Flatbottom Construction Report 13 Sep 2024 18:23 #1
  • marshd
Starting the construction by making the plans. I have the lenght and width. Looking at a lot of pictures to come up with the rest. This will take some time...
Folgende Benutzer bedankten sich: Klemens, Kay_01, Floh, OldGun
Flatbottom Construction Report 15 Sep 2024 16:53 #2
  • marshd
I'm thinking using 1/8" plywood for the bulkheads.
Also, 1/8 x 1/4" for the stringers and double it up to make 1/4" x 1/4" after gluing?
What about the bottom and sides? 1/16"?? Solid mahogany or plywood?
Flatbottom Construction Report 15 Sep 2024 19:23 #3
:lesen: Sperrholz :muetze:
Flatbottom Construction Report 16 Sep 2024 13:21 #4
  • OldGun
  • Dank erhalten: 636
Tika says: Use Plywood !
Flatbottom Construction Report 16 Sep 2024 17:41 #5
Plywood. More durable, and at the same time a litthe flexible when in a collision. Mahogany you can use for deck, or sides as well but coat it with laminating epoxy.
Flatbottom Construction Report 16 Sep 2024 23:17 #6
  • marshd
Ok, thank you all for the comments.
I will be having the bulkheads and keel laser cut, so I need to tell the folks cutting the parts what thickness wood for each part.
Flatbottom Construction Report 17 Sep 2024 22:42 #7
  • marshd
My brother builds full size wood boats (see picture of his latest boat).
. I showed him the boat I want to build and He asked me if it is possible to get tiny screws?
It says on this website to use actual construction techniques, so these tiny screws might be available somewhere??
Anhang:
Flatbottom Construction Report 18 Sep 2024 09:15 #8
Tiny screws: Click
Folgende Benutzer bedankten sich: marshd
Flatbottom Construction Report 19 Sep 2024 01:35 #9
  • marshd
Flatbottom Construction Report 19 Sep 2024 01:39 #10
  • marshd
Bob Switzer won our Michigan Marathon race in 1952, so I wanted to recreate one of his boats.
I see the Baby Bullet kit is no longer availale. So, I'm drawing up my own plans.
I wanted a little bigger boat than the 'Baby' , so I chose a the 13'6" "D" Class Bullet. Did a lot of on-line research to get pictures of the boat so I can make the plans the best I can from pictures, without having the full-size boat to measure.
Folgende Benutzer bedankten sich: Klemens, Hasse.69, Maxxxmax
