Start Das Forum Die Technikecke Outboarder Zugeschaut und mitgebaut: Semiscale-ABs von Rod Geraghty
THEMA: Zugeschaut und mitgebaut: Semiscale-ABs von Rod Geraghty
Mercury Six Cylinder Rennmotor 15 Aug 2016 12:06 #21
  • pasilva
  • Dank erhalten: 2
Hello
Although I read, write and speak american and british english it is hard for me to understand google english. So i try to look at the pictures. Here they are very nice and this Mercury mark 78, is the motor I need to build for my Airmarine Special. The problem I found is the lack of measurements.
Some measures from propeller centre line to bottom of the first cylinder, to the top of 6 cilinder, also the width of the cylinder block, plus crankshaft case would be very much apreciated.
Mercury Six Cylinder Rennmotor 15 Aug 2016 17:45 #22
hi Pasilva
welcome to the 152vo forum :tusch:
Folgende Benutzer bedankten sich: pasilva
Mercury Six Cylinder Rennmotor 15 Aug 2016 18:02 #23
Hi Pedro,
just write an >> email to Rod Geraghty and he will help you with the measurements.
Regards, Jo
Mercury 40 ci 4-Zylinder "Ring of Fire" 14 Dez 2021 22:13 #24
  • VO152Maine
  • Dank erhalten: 47
Does anyone know who has this engine?
... und noch jede Menge Kleinteile:
Zündkabel, spray shield (damit kein Spritzwasser in die offenen Ansaugtrichter der Vergaser gelangt), Farbe... und zum Schluss das schicke Ergebnis:
So, jetzt habt ihr wieder ein bisschen was zum gucken! :yepp:
Hoffen wir mal, dass Photobucket die Technik besser im Griff hat als Hostarea. Da der Laden wesentlich grösser ist, stehen die Chancen gut.
Zugeschaut und mitgebaut: Semiscale-ABs von Rod Geraghty 18 Mär 2022 17:34 #25
Sorry Zach, I missed this thread and your question, but yes I do - I have this engine. Rod sent me this one and I built the Airborne for him. The Foo Ling, VO-152, had been built by Andreas Grabski aka Vollnormal. The number VO152 was given to this boat, because Rod helped us a lot with all his knowledge.
Zugeschaut und mitgebaut: Semiscale-ABs von Rod Geraghty 18 Mär 2022 17:40 #26
Here is the beauty. I have it currently disassembled, but I have the complete drive including K&B lower leg and the fuel tank by Marshall Grant
I actually try to draw for 3D printing - that´s why I took it off the leg
Zugeschaut und mitgebaut: Semiscale-ABs von Rod Geraghty 05 Apr 2022 15:50 #27
After that one is off and back to USA, here is a sneak peek what´s coming up for my frustrated driver
It will have a Mount for the tfl mini and for the k&b 3,5, but can easily be adapted to others. When it is finished, stl files will be public at thingiverse again
Folgende Benutzer bedankten sich: Klemens, jan, Hasse.69, Floh
Zugeschaut und mitgebaut: Semiscale-ABs von Rod Geraghty 12 Apr 2022 10:45 #28
Ich habe die Daten für den Merc 40ci jetzt auf Thingiverse hochgeladen und frei zugänglich gemacht unter der üblichen cc non commercial Lizenz, zu finden am einfachsten über den Begriff Merc 40ci oder einfach hier .
Dort sind jetzt an einem Ort alle Einzelteile versammelt. Ich habe einiges separat als Datei gemacht, auch wenn man z.B. den Zylinderblock in einem drucken könnte, anstatt ihn aus vier Teilen zusammenzubauen. Duplizieren (Megaphones, Zündkerzen) und positionieren wie immer im Slicer.
Viel Spaß!
Folgende Benutzer bedankten sich: Klemens, Henne, Hasse.69, Floh, Car S ten, VO152Maine
Zugeschaut und mitgebaut: Semiscale-ABs von Rod Geraghty 12 Apr 2022 14:13 #29
  • VO152Maine
  • Dank erhalten: 47
Andy,
Your contributions to the hobby are great. I will fire up the printer tonight.
Thanks,
Zach
Zugeschaut und mitgebaut: Semiscale-ABs von Rod Geraghty 12 Apr 2022 19:25 #30
  • ONLINE
Viel Spaß!
Ganz ganz dicken Dank :shakehands:
