Today I made 2 runs with the Corsair.
I ran the Corsair the first time last week. I noticed the setup could be improved, so I made some changes:
- Place the lipo left of centre to compensate for the drive torque / tiliting the hull to the right.
- Place the outboard a little higher, because the prop was fully submerged. New setup: 75% submerged and a little down tilt.
The Corsair now needed some time to get up to speed. The prop sits a little too high now. Also in the corner the prop loses some grip and the hull starts to jump up and down.
On the other hand; She runs very stable now! Now sign of torque roll and almost free of the water surface at full speed. And fast she goes: 52.3 km/h
I know I know, it's not scale speed! I will change the motor for a 2700kV and maybe even go for a 2500kV lateron. After all I still need to sharpen the outboard arc, which will increase the speed even more.
The 2nd lipo the Corsair suddenly stopped but I could hear the motor spinning. At the shore I found out the flex shaft broke :( And even put a hole in the Teflon tube!
Anyway, I will soon fix it and put her on the water again. I promise to make another decent video as well for you guys lateron.
* Also in the making: the bow handle and the gas tank. Update will follow
