Start Das Forum Die Backyard-Werft: unsere 152VO-Modelle Utilities / Flatbottoms Speedliner Corsair, the Dutch way
THEMA: Speedliner Corsair, the Dutch way
Speedliner Corsair, the Dutch way 08 Jul 2017 18:48 #71
:schwitz: Kann mir das jemand erklären :kopf3: verstehe ich nicht :lesen: :blink:
L.G. Gerhard
Speedliner Corsair, the Dutch way 09 Jul 2017 11:00 #72
  • Jürgen.NL
Dirk Jan: I did that because I had contact with A/B Speedliner (David van Weele) he build the 1:1 boat and send an picture of a drawing and the explaining. the use of it is indeed having better cornering.
Snake: This way if you stand by the boat and look at it it looks like the steering cables are reall.
Yesterday it was time for the maiden run, I put the video online on my dad his youtube channell because i dont have one :)
KLICK
The maiden went fine! on the straight line she jumps a bit, I'm trying to make this as small as possible by trimming the motor. the corners went perfect she goes around corners as planned, reall stable and fast. verry pleased with the top speed of 59km/h :pogo:
Folgende Benutzer bedankten sich: jan, Snake
Speedliner Corsair, the Dutch way 09 Jul 2017 11:05 #73
  • Dank erhalten: 3168
in addition to Jeroen, here are the 'tech resutls':
The topspeed (59km/h, second piek in the graph) was acheeved with a fresh battery, on average the boat runs 54 to 56 km/h top. That should do I think .. :) The cornering is realy faboulous! Since half of the Closed Course are corners I am verry courious how the boat will performes in the upcomming races :pogo:
Speedliner Corsair, the Dutch way 09 Jul 2017 17:50 #74
  • Class C Hydro Racer
  • Dank erhalten: 1864
:super: :super: :super:
Folgende Benutzer bedankten sich: Jürgen.NL
Speedliner Corsair, the Dutch way 10 Jul 2017 21:27 #75
  • Dank erhalten: 752
That is one SERIOUSLY SICK boat.
Speedliner Corsair, the Dutch way 11 Jul 2017 12:29 #76
Great performance! The bouncing is a cracteristic of this hull with this kind of speed. Mine does exactly the same. Cornering is great, better than mine! These fins seem to work well 8-)
Enjoy your new boat and take home the trophy :rc:
Speedliner Corsair, the Dutch way 13 Sep 2017 00:12 #77
  • A/B Speedliner
  • Dank erhalten: 146
The ride of the boat is nearly like the actual boat, a lot of the proposing is due to the prop, where is the center of gravity of the boat with the pilot in the boat, it should be near the location of the center fin.
Your version of the Corsair is very well done.
David van Weele, I will be in Amsterdam in for a day on Sept 26.
Speedliner Corsair, the Dutch way 20 Sep 2020 18:22 #78
Für Derjenige dem es interessiert, die 'Iceman' ist im Moment zu haben, sehe die Biete Seite
