Start Das Forum Die Backyard-Werft: unsere 152VO-Modelle Utilities / Flatbottoms Speedliner Corsair, the Dutch way
THEMA: Speedliner Corsair, the Dutch way
Speedliner Corsair, the Dutch way 07 Okt 2016 17:59 #1
  • Jürgen.NL
Hello,
I started building my first 152VO boat, a Speedliner Corsair. I'm building this boat because I want to own a 152VO my self, it's exctualy my first build on my own ever. I choose the Speedliner Corsair because I wanted to have a Flatbottom and the Corsair is a nice streamlined boat (in my eyes). I also want a fast boat that is capable of going fast, and steady in corners too.
Here are the first building pictures.
I got a set of frames from Jan, so that will make it a bit easyer for me.
Me doing some modifications (closing up some of the frames)
Glueing the frames on the building board
The actual building board with all the frames
Now i have to wait until my wood for the stringers and battens arrives.
Folgende Benutzer bedankten sich: A/B Speedliner
Speedliner Corsair, the Dutch way 07 Okt 2016 18:08 #2
  • Randy_1978
  • Dank erhalten: 7
Really nice built so far!
:1st:
Speedliner Corsair, the Dutch way 07 Okt 2016 19:49 #3
Hi Jeroen
That is really a nice surprise. If your first boat becomes nearly so good as you will drive it, it will be a hammer. And I think you have an acceptable fallback at home!?
Good luck, Kay
Speedliner Corsair, the Dutch way 08 Okt 2016 08:57 #4
Very nice Jeroen!
Next year! :bier: :rc: :1st:
Speedliner Corsair, the Dutch way 08 Okt 2016 10:55 #5
Aha!! That's where my building board went! Could'nt find it anywhere last week .. ;) That board was already used to build four 152VO Racers, so it's a good base for an exelent boat :bauen: I hope the wood arives soon so you can continue the build :muetze:
Speedliner Corsair, the Dutch way 08 Okt 2016 11:34 #6
:idee2: hallo Lex, jetzt kommt die Zeit, in der dein Werkzeug Beine bekommt! :bauen: :sick: :colera:
:idee2: Hi Lex, nu komt de tijd dat je gereedschap krijgt benen! :bauen: :sick: :colera:
Speedliner Corsair, the Dutch way 10 Okt 2016 17:53 #7
:super:
TOP
mooi werk Jeroen
Speedliner Corsair, the Dutch way 16 Okt 2016 14:47 #8
I have drawn some fittings for the Corsair. The steering wheel, Quincy Bisumatioc and Bowhandle are new, the rest are copies from the Humarock Baby.
A litte help from Dad is allowed ..... :shakehands: :bier:
Speedliner Corsair, the Dutch way 16 Okt 2016 18:53 #9
  • A/B Speedliner
  • Dank erhalten: 146
This the USA Dutch way! The picture show how we built the Corsair M510 1960 onward. This was a close front cockpit.
David van Weele
Folgende Benutzer bedankten sich: Lex Verkuijl, gema1831, ruefy
Speedliner Corsair, the Dutch way 16 Okt 2016 20:04 #10
...I have drawn some fittings for the Corsair. The steering wheel, Quincy Bisumatioc and Bowhandle are new, the rest are copies from the Humarock Baby...
...A litte help from Dad is allowed ...
Hi Lex
I know how you feel and I can read "the tingling sensation in your fingers". But keep in mind - it is the project of your son. He has to make the same expiriance as you. The only way of learning.
Be a coache and not the better model builder. :bier:
Best regards, Kay
