Start Das Forum Die Technikecke Outboarder Crescent CS500 - alter Schwede
THEMA: Crescent CS500 - alter Schwede
Crescent CS500 - alter Schwede 27 Feb 2022 22:42 #41
Floh schrieb:
Ha...
Oder sind das die bekannten Fehler mit den zu dünnen Wänden, die Andy weiter oben schon erwähnt hat?
Schau ich mir mal an.... morgen ... 8-)
Crescent CS500 - alter Schwede 27 Feb 2022 22:53 #42
VO152Maine schrieb:
Does anyone have a picture of how the clamp is used to mount a TFL/ OSE lower to the transom?
Thanks
This is what i use.
Folgende Benutzer bedankten sich: Andy, VO152Maine
Crescent CS500 - alter Schwede 27 Feb 2022 23:15 #43
Printed already, assembling still to be done. Will follow soon :popcorn:
Crescent CS500 - alter Schwede 28 Feb 2022 23:11 #44
  • VO152Maine
  • Dank erhalten: 47
Thanks for all the help on this. Last question- Where are you terminating the spark plug cables?
Stay safe,
Zach
Crescent CS500 - alter Schwede 28 Feb 2022 23:30 #45
I have not done that yet but the Plan is to lead the three cables to the base of the fly wheel, which carries the magnets for ignition
Maybe I should make three holes into the fly wheel :bauen:
Folgende Benutzer bedankten sich: VO152Maine
Crescent CS500 - alter Schwede 01 Mär 2022 02:18 #46
No not on this one, they use 3 separate coils. (Like a beercan) Mmmmm, beer. :bier:
Or like in this picture, 3 coils on a plate. (I think this is a newer setup)
I was wrong no beercans. (Still like :bier: though)
Crescent CS500 - alter Schwede 01 Mär 2022 15:44 #47
  • VO152Maine
  • Dank erhalten: 47
I found the same thing. Mounting them on the front of the engine above the fuel pump would look really good. Anyone have a drawing of a coil pack?
Thanks,
Zach
Crescent CS500 - alter Schwede 01 Mär 2022 17:12 #48
Thanks,
Zach
Not yet :popcorn:
Crescent CS500 - alter Schwede 01 Mär 2022 21:59 #49
  • VO152Maine
  • Dank erhalten: 47
Here is my first cs500. This one isn't very detailed. I always like to build one first before putting a bunch of time into it if possible. This allows me to see how everything goes together. I always make at least one mistake on the first one. I also just got my first 3d printer so I am still learning the ropes and having fun printing parts. Plug wires are just tucked into the case for now.
Anhang:
Folgende Benutzer bedankten sich: Andy, studioRS, Floh
Crescent CS500 - alter Schwede 01 Mär 2022 23:09 #50
This is exactly what I intended. I had no experience at all in 3D construction neither in 3D printing, but this is fantastic to see. Thanks for that!.
